Have a problem....spent 2 days putting a Fisher plow frame on my 85 Suburban K-10...wasn't fun,and now I kida wish I hadn't put it on it..
The plow frame was "modified" by the previous owner--evidently the truck it came off was a lifted one,and someone decided to drop the push bar down 4" from the usual factory position to compensate for the lift kit..they did a decent job,too good in fact--to restore it back to "normal" would entail much torch cutting and then I'd have to re-fab the push bar to fit in its original spot..the genius who did this mod also decided welding the entire push frame AND the upright lift frame together was a good idea,made it a real beotch to install...
I was aware of this when I put the thing on,that it would hang lower than a typical plow frame would,but my '82 K2500 has a home brewed plow push frame someone made by boxing in the front of the frame rails,coupled with a typical Fisher lift frame--the push bar on this truck is only 8-1/2" off the ground with no plow on it,and I've never had it hit bottom the 6 years I've driven it,even with the blade on it..since the plow frame I'm putting on my Suburban had the same measurments from the truck frame to the bottom of the push bar I figured the 4" "drop" wouldn't be a big deal...
BUT..
I didn't take into consideration the 'Burb only has 225/75/15" tires and sits a lot lower than my 3/4 ton with 245/75/16 tires does !..the bottom of the push frame is a mere 6" off the ground,and I fear once I put the blade on it (a HEAVY mother,ruggedest one I have seen by Fisher in a 7'6" size!),I am betting the push frame will be only 3-4" off the ground!..
So,I have a few options now..
1. Cut off the previous owners hackery and re-do the push bar,so it fits where it was meant to be again..--a lot of work and I'm not so great at cutting things with torches that will be re-used--I'm more skilled at hacking vehicles apart with one than "fabbing"..
I'd rather not go this route unless I have too..
2. Get larger tires..I have 6 lug rally wheels 8" wide ,so I could use up to 31" tires with no problems with rubbing fenders,etc..they would jack it up at least 2-3",that alone might be enough to avoid having to do anything to the plow frame..
3. Get a pair of 4" lift kit springs ...but I am not a fan of lift kits and hate dealing with u-bolts and bull work...I thought maybe I could use some shackles on the rear of the front springs to gain an inch or two,but that will probably throw off the caster and make steering hard and I'd rather not make more problems solving another!...I'd also have to lift the REAR to compensate,and I would rather leave the truck stock..
4. Add helper springs to the stock leafs,or jerry-rig some coil overloads between the bump stop brackets and u-bolt plates to gain clearance...
I thought about air shocks and those shocks with helper coils,but these thucks crack the frames around the upper shock bolts too dam easy for my liking,and I've seen some disaters result from using air shocks up front,when one suddenly loses air pressure!..
I think the bigger tires might be the easiest way out,though it wont be easy finding 4 good 31" tires for cheap money..I suppose I could go junkyarding and PAY for another unmolseted plow frame,but few exist here and they want a good chunk of change for any plow stuff this time of the year..besides,I'd rather use what I HAVE...I traded a good garden tractor for this plow setup..good thing the blade is mint and one of the beefiest ones I've ever seen,otherwise I'd be wishing I had that tractor back!..
What would you do??..opinions??
...keep in mind I'm living on ramen noodles and dont have a lot of cash to blow...
BUT..
..So,I have a few options now..
