Does anyone have a good idea how to add in the plow frame lights to the lighting sytem. For example, my thought is to add in a switch so when the plow is on the truck the plow lights are on when you pull out the light switch and the lights in the grill are off so you dont get the relection back from the plow. and when the plow is off I can switch the switch and run the factory lighting. Is there a way to splice this into the existing wiring?
