i am always on the look out for this stuff. this is the best i have found so far.
i got 1 of these kits about 1.5 years ago. it has everything you will need to mount it to a aluminum style serp belt setup. has new hoses/cables/dist block mount/hardware/crank pulley/drive belt/joystick unit/directions. wont have pump/dist valve unit.
if you need i can take a few pics of how i used it and mounted it in the truck. i flush mounted my joystick in the dash in were the a/c vent hole would be if i had a/c. works perfectly.
