bigbadchev84
got a head scratcher here.
My brother in law owns a 97 lexus es300 V6. its got 187,000 on the clock and he told me its been running like crap and the check engine light is on. I had him go to autozone and have the codes read. It said engine misfire.
So had him pick up some plugs and head to my place, when he got here it sounded horrible, thing was chugging and sounded muffeled. he said it didnt have any power and crappy gas mileage. it idles ok, but when you put it in gear it starts chugging and running really rough.
Since he bought it it has always smoked a little bit from burning oil. I pulled the plugs and they had a little burnt oil build-up on them, put the new ones in and only a slight improvement. I guessed his cat was plugged, as it sounded like the thing was having a hard time breathing.
we took it to the muffler shop yesterday to have it tested, sure enough it had 6lbs before the cat, he said 3lbs was really bad and needed replaced.
he also said that it was not the problem gauranteed and that he would put a new one on, but would not warranty it because the check engine light was on.
So anyone know where to go from here? he dosent want to dump alot of money into this, but needs it running good enough until he can trade it in. i noticed there was a 02 sensor behind the cat, would this have any effect on it since the cat is not breathing the way it should?
