Plugwire Ohms
BlackBourbon
Sherman, TX
Did a bunch of searching around and didn't find what I wanted. I just smoked a set of ACCEL plugwires in like 1500miles. I didn't do any research bfore I bought them and now know they are garbage.
I am looking at Taylor wires from Summit cuz that's what I hear a lot of good things about on here. Question is, do the ohms have to be a certain amount for TBI setups? For example here are the two sets I am lookin at but one set is a little more for a lot less ohms(aka better spark). I just don't wanna grab that set and have problems. The two I'm looking at are the Spiro-Pro and the Thundervolt. Different Ohms, core material and diameter. On the Spiro-pros it has a note for TBI Only whereas the Thundervolts don't.
In Summit's magazine it says the the Spiro-pros are 350ohm/ft and the Thundervolt ~50ohm/ft.
http://www.summitracing.com/parts/TAY-74628/
http://www.summitracing.com/parts/TAY-84628/
Buy MSD wires and never look back. I've been running them for 25+ years now without any issues.
I run Taylor spiro- pro on my hot rods. They last a long time and hold up to heat very good. MSD are good wires too. Taylors are just as good IMO and cost less.
I must have had a couple bad set of Taylors then (once installed i had a bad mis so i fired the engine up at night to watch the fireworks display under the hood). :crazy:
This was more close to when Taylor first came out though so maybe their wires are better these days. I just figure if MSD wires are used on EVERY 8000hp funny car engine they should work perfect on my 400hp engine. :thumb:
