pauly383
Daddy383
Well try it again . Maybe snug it up and wiggle the carb a bit , and tighten . Then check the edges .
Those gaskets and those carbs work fine , maybe it doesn't like that intake flange .
Thats your trail truck motor ? If ya want a good factory dual plane aluminum intake , Id swap that with ya . You don't need it with a trail truck , and I know the factory carb flange will seal .
