Pointers on a [DIESEL] '83 Blazer....
TheBeast_88K5
Banned
[Far away.]
I might be trading my Diesel F-250, for a Diesel '83-K5.
It's a 100K, Family-truck, survivor.
Supposedly it's unmolested, minus a 4" lift.
I just need pointers on what to look for, on an '83 Diesel.
From the sounds of it, it's just a plain old family rig.
I know about the normal truck/k5 stuff...
Like frame cracks, steering slop, modifications, etc.
I just wanna make sure there's no particular things, I need to look for... :thinking:
Like those little, "GM designed _____ screwy. So, you need to make sure it's still attached." - things.
check the motor out
for signs of oil leaking..i assume its non turbo (or no turbo added)
anything missing (a/c etc) Make sure it starts and runs good.. Drive it. look for signs of bogging, or over revving, in case the transmission is beat on or the motor has a knock or tick thats being covered up. Maintenance logs? added performance parts added (installed correctly)
rear end play? kid owned or adult owned? ( i know some dumb ass people that would neutral drop etc and then tell you its never been beat on)
since you are in cali i would make sure that all the smog stuff is there for sure.dont know what kind of inspections if any there are on diesel trucks.im guessing you wont have to worry about rust as well.id look for leaks around the injector pump and also how long it takes to start.low compression from worn engine will take more to crank up and get the compression high enough to burn the fuel.watch the exaust and see how quick the smoke clears after it starts.if it stays black or smokes a lot could be worn rings or leaky injectors.basic use the truck in all gears and transfer case in all gears and look for leaks and anything that feels worn.
check the motor out
Makes sense...
- It's n/a (non-turbo).
- It supposedly is BONE stock, 'cept for the lift.
- I always check maintanence papers.
*If I don't see it on paper, it never happened, imo. :waytogo:
*I'm currently arguing w/ the Ford dealership, for the engine rebuild papers, on the F250.... From 2000.
- I'll check for oil leaks, but everything I own leaks oil. :haha:
- I wanna see how many owner's she's hadm for sure.... :thinking:
Also:
How do the 6.2's do on road trips?
Are they total dogs?
I'm gonna swap my axle's under it.
So, I'll be on 4.10's.
If I ran 33" tires, how would it tow a trailer>?
Say a 2,500lbs. one....?
I guess the easiest way to ask, is: "How do they compare to a healthy, stock 350tbi."
Also:
If you give me enough notice I can go with you to check it out. As for comparison, it's as good as a stock 350 but twice the mileage.
Now with a turbo added, it will be like a healthy 350, and 3 times the mileage.
It will easily pull a 2500lbs trailer.
How bad is the mileage on your 350's? :eek1:
It'll honestly double the mileage of a 350, towing or not. Mine towed a 4000 lb trailer 900 miles just fine. I had issues that were unrelated to the 6.2...plugged fuel filter at one point (my fault) and a 4 month old starter that packed it in once we got here. Other than that it towed fine and averaged 16 mpg doing it.
Towing similar with my old 350 usually netted me 6-8 mpg.
Empty it averages 22-24 mpg on the highway, and about 20 in town.
Go browse the diesel forum here, lots of info and known issues to read about in there.
After you drive it, check for bubbles in the coolant overflow.
6.2s get stupid mileage unloaded (18-25) but mpg drops fast with any load.
Power depends ALOT on elevation with these things, to compare one here to a tbi 350, I would say 3/4 the power but twice the mileage compared to a tbi 350.
Thanks for the info, all around.... :D
My tbi350 gets about 10-12mpg.
I hadn't really considered mileage, but that's a huge plus.
I just want a decent, unmolested rig.
I could toss the frame braces on, do a shackle flip, swap my axles in,
and be smog free, in a nice rig.
Hopefully....
I love my 89 it gets about 18 mpg average, I use it to tow Horton, not so much fun but towed a Jeep the other day with it and it was a breeze. Well not a breeze but it wasn't a big deal.
4.10s with 33s oughta work well, I have 4.56s with 35s and I like it
Id be weary of the 700r4 if its an auto. never know what some ****head has done in the past, and theyre not overly strong when stock.
I'm kinda leaning toward the BTO Level 2... :thinking:
http://www.bowtieoverdrives.com/catalog/catalog_inc/viewitem.php?ITEMID=503
[FONT=Verdana, Arial, Helvetica, sans-serif] Description[/FONT] [FONT=Arial, Helvetica, sans-serif]
[FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]High Performance Street[/FONT] - $1395.00[/FONT][FONT=Arial, Helvetica, sans-serif]
HP/TQ Rating = 450/500 Maximum
[/FONT]​
[FONT=Arial, Helvetica, sans-serif]For 4X4 applications. This Trans requires a Transfer Case Specific Output Shaft, Call for Details [/FONT]​
[FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]Our Level Two Transmissions have all the wonderful features of our Level One Transmission, but they're built significantly to handle more horsepower, plus they feature [FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]quicker and[/FONT] firmer shifts. These units are still very street able, however, they should be installed into performance oriented cars and trucks. They will handle a steady diet of around 450/500 hp and 400/450 ft/lbs. of torque. This Level Transmission is definitely a huge step up from what the popular brand name companies' offer (according to their descriptions) and they still charge more! We have sold thousands of this Level Transmission over the last [/FONT][/FONT][/FONT]ten [FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]years with tremendous success. This is our most popular [FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]Level[/FONT] Transmission with years of refinement that's proven to be very reliable and tough in serious street performance vehicles.[/FONT]
[/FONT][FONT=Arial, Helvetica, sans-serif]These Level Two Transmissions feature all the components and modifications built into our
Level One
Transmission, plus the following upgrades:
[/FONT][/FONT]​
[/FONT][FONT=Arial, Helvetica, sans-serif]· [FONT=Arial, Helvetica, sans-serif]29 element input sprag clutch.[/FONT]
· Premium after market frictions used throughout all clutch packs.
· [FONT=Arial, Helvetica, sans-serif]Larger, custom machined servo assembly in beautiful blue anodizing!
[/FONT]· [FONT=Arial, Helvetica, sans-serif]Accumulator circuits modified for quicker, applies during 1-2, 2-3 and 3-4 shifts.[/FONT]
· [FONT=Arial, Helvetica, sans-serif]Main boost valve is upgraded to a .500" main boost and our oversized low/reverse
boost valve produces higher operating pressures for firmer, quicker shifts and better
clamping pressures in all gears.
[/FONT]· [FONT=Arial, Helvetica, sans-serif]Modified line bias system.[/FONT][FONT=Arial, Helvetica, sans-serif][/FONT]
· [FONT=Arial, Helvetica, sans-serif]Special intermediate servo release check ball.[/FONT][FONT=Arial, Helvetica, sans-serif][/FONT]
·[FONT=Arial, Helvetica, sans-serif] Modified governor to raise W.O.T. shift points.
[/FONT]· [FONT=Arial, Helvetica, sans-serif]Re-calibrated pressure curve for quicker pressure response off idle, a must for big blocks, stroker motors, blowers and nitrous.[/FONT]
· [FONT=Arial, Helvetica, sans-serif]Of course, these Transmissions have our precision machined pump assembly described in our Level One details [/FONT][FONT=Arial, Helvetica, sans-serif]but they
also feature hardened steel pump guide rings to prevent breakage in severe high rpm operating situations.[/FONT][/FONT][FONT=Arial, Helvetica, sans-serif][/FONT]
·[FONT=Arial, Helvetica, sans-serif] Nine frictions and steels in the 3/4 clutch pack. This upgrade is a must for high performance use, along with our special
spring kit for quicker 3/4 clutch release.
· [FONT=Arial, Helvetica, sans-serif]Extra wide (3/8") Kevlar band with heavy duty anchor.[/FONT][FONT=Arial, Helvetica, sans-serif][/FONT]
· [FONT=Arial, Helvetica, sans-serif]New transmission pan with drain plug.[/FONT][FONT=Arial, Helvetica, sans-serif][/FONT]
· [FONT=Arial, Helvetica, sans-serif]Automatic fourth gear and manual converter clutch lock up system installed in all custom applications at no charge.[/FONT]
[/FONT]
^That says "Performance oriented applications".
Would this be okay for a rig that:
- Has a stock 6.2 diesel. (will do Banks turbo, eventually.)
- Drives about 30 miles a day, city/freeway.
- Drives to the trail/wheels on weekends.
- Ocassionally, drive a couple hundred miles, on road trips.
a few years back when I was having trouble with 700s in my diesel burb, I called one of the hotrod 700 builders. They said even though the trans was rated for 500ftlbs, that it was not diesel rated.
Might want to ask them about that?
I have a feeling that they just figured I was going to be trouble since I had broken 5 in 5 years.
Yea... I've only gotten one to it's last leg, in two years. :haha:
Obviously, I'll call and talk to them about it.
Don't even know if I'm getting the rig, for sure, yet... :D
