fulltilt
Registered Member
Has any one attemted to P&P a set of LO5 heads with good results, it so How did you massage the intake side?
The reason i ask is that when i poped the valves out of the intake side, i found something i have not seen before. In behind the valve is what apears to be something cast into the head to create a swearl? Hopefully someone knows what i'm talking about.
I have P&P several late 60's and early 70's heads over the years great results and hopeing for the same with theses heads as well.
Any help would be great.
