original balzer
I realy dont know how to go about a project. I have the trucks listed below, Id like to throw the best parts together into one truck.
1)1983 chevy k20;6.2(bad), sm465, 208, 10b, 14bsf. Body damage and a little rust.
2)1985 gmc k5; no engine, sm465, 205, D60, 14bff. No title, frame is BAD shape.
3)1979 gmc c20;6.2(good runner),sm465(pto), 14bff. rusty cab floors, 2wd, cracked frame.
I also have these parts layin around: 3-2wd steering boxes 1-np203 transfer case(32spline) 3" lift springs, 4" lift ft springs/blocks and about 4 sets of add-a-leaves(nuff to do 4 axles) several small blocks and a few big blocks. also about 3 other gm trucks in various states of dispair.
What I want is the CC on a shorter frame, small purpose built flatbed, 1 tons, doubler, exo cage. You can imagine all the extras.
Components and what they need done:
D60- crossover, hydro assist, gears, detroit, rebuild kingins, bearings, 1410 yoke
14bff- gears, detroit, shave, disk brakes, bearings, 1410 yoke
SM465-rebuild as needed, change parts to fit doubler.
NP203- rebuild as needed, parts for doubler.
NP205- same as above, 1410 yokes.
opp. 1) would be strip the 83 down and begin the build from start to finish. This leaves me without a toy at all.
opp.2) change engine in the 83 with the one in 79, add lift, wheel as is. Build/rebuild components I want in final version. Swap it all in later.
opp. 3) fix 83 wheel as is, and use the c20 CC as base for build up. This saves cab mods to fit, BUT involves converting the frame to 4wd.
opp. 4) rebuild components as needed, and shop for a better project base.
How would you guys go about this?
Balzer
Balzer
