Poly/Greasable Spring Bushings
prairie
NE Nebraska
Had em without, had em with. Can't feel or tell a difference, on an RTI ramp there was no difference in between the two.
That said it is going to reduce friction for sure.
New greasable vs. New non greasable, there is no difference.
If you do the maintenance and hit the zerks on a regular basis, 5 years from now there will be a noticeable difference especially if you live in the rust belt.
cybrfire;2893082...If you do the maintenance and hit the zerks on a regular basis said:
That was my line of thinking also. I am sure that the 27 year old rubber spring bushings are probably not as pliable as when new, and it appears to have spent its life in the rust belt.
Think I'll toss them on when I get the chance.
You have a CUCV. You probably won't notice a difference with noise or ride. Longevity sure.
