The diesel wiring is an add-on harness for glowplugs (light and control) and water in fuel light, everything else is identical for the motor and cab. You will need to extend the HEI power wire to run the IP fuel shutoff solenoid at the front of the motor though. The cruise control circuit is also different than the gas on the engine, but a stand-alone harness as well.
