black dawg
Digging one out of the weeds, parked a little over a year ago because I couldn't get it to drive right.
90 v1500 burb converted to 8 lug stuff, stock height stock 235/85/16
This is one my wife drove mostly, with no complaints?. Driving on perfectly smooth flat roads it would drive pretty close to perfect, but any slight ruts or lines in the road would cause all kinds of unpredictable stuff. Noticed the poor return to center then, but figured it had bigger issues also.
So, a few weeks ago, finally got it on an alignment rack and found that the right rear was toed out almost a degree. No idea how it got that way, most likely was that way when I put it in. Got the housing straightened out last weekend, and all the unpredictable stuff seems to be gone, but have this return to center issue. Corners in town you have to turn it basically all the way back to center, at highway speeds it is better but still have to help it back to center......feels like an overtightened steering gear, but it isn't, and have tried a couple different ones on it. Have had everything apart down to the ball joints and axle joints, every thing moves freely like expected.
Has 6 deg pos caster, don't remember camber, but was in spec and looks fine.
Interesting part is that it returns to center almost perfectly in reverse??
any thoughts...suggestions?
