buff_dog70
I have a Mile Marker 12,500 lb hydraulic winch that runs off my Super AGR power steering pump. I was using the winch this weekend and I thought the winch would pull hard. With the vehicle on ashalt, not tires aired down, I was pulling against a immovable point the vehicle would not pull it self across ground. This was all done at engine idle.
Does revving the engine help the power steering pump push the hydraulic winch to pull harder? This is the first time I have used the winch to pull something hard, and was less than amazed. Any suggestions. A mechanic friend said that the device that creates vacuum (6.2 liter diesel) might have a small leak. It there a easy way to check line pressure, detect leaks, (except for puddles).
