badmix
It seems to be happening more often, but I get a popping noise when Im driving truck on pavement and jus barely turning the wheel and if I hit small bumps. Nothing feels loose thru the steering. What things should I check for?
Take a close look at your drag link ends..........![]()
the ends of the link between your steering box arm and the axle
). So everything is good. I even checked / looked at the motor mounts, they seem to be fine. The noises are like popping and creaking, a mix really.You mentioned there was a leaf spring twisted out a bit. Leaf springs can move back and forth a bit and cause a popping noise. My stock ones did this on the left side at the front of the spring pack. You can get someone to turn the wheels back and forth while you watch the springs and see if they are doing this. I fixed mine by installing my 4" lift springs.
You're draglink is shot. I still think you have a crack in the frame.
I would unbolt the steering box and give the frame a good look.
Sure, If they move easily and wont hold grease, I would replace them.Think it would be a good idea to replace the tie rod ends as well?
