I just put a rough country 4 susp lift, all spring lift,all new shocks, all new steering stabilizier. When you turn the steering wheel 1/4 a turn left or right it will make a dull pop noise. I rechecked all the bolts on the susp all tight, and there isnt any sign of anything moving(i.e. no shining spots around the bolts/washers)
So I had my friend turn the steering wheel back and forth to make it pop.
Checked the drag linkage couldnt feel it there
checked the steering box couldnt feel it there
checked the steering shaft to the steering wheel not there
checked the tie rod not there
the closest we could locate where the pop was coming from was when we put our head between the 2 frame rails and below the radiator, also I did a quick check and didnt see any sign of the frame around the steering box to be cracked, but I didnt think to put my hand on the frame, maybe ill do it later
any ideas on what to check?
thanks,
woods
thanks,
woods
