My '90 Sub has been having troubles that has gotten progressively worse over the past two weeks. It started out as a slight stumble at times under load, then it got worse. It would severely stumble on moderate to hard acceleration from a stop. Now it's popping back through the intake when it stumbles. I've swapped out the cap, rotor, module, coil, and fuel filter. I'm gonna replace the pickup coil tomorrow. It got a lot worse today after I replaced the ign. coil. Before, it wouldn't do it while brake torquing it, now after the coil replacement it will. Any ideas?
