I know what everyone is going to say: get the ORD brace and weld in piece. Well, I've done that (did it about a year and a half ago). Problem is, the problem has persisted, if not gotten worse.
My front end is greased properly, and the frame is well supported where the steering gearbox is mounted, the mounting bolts are torqued correctly and haven't come loose.
Yet, I still get popping and cracking noise when I turn the steering wheel.
The next step I'm thinking is replacing the steering gearbox, since I can feel the box popping when I lay under the truck and have a friend turn the wheel, but there is no visible movement between box and frame.
Thoughts?
Thoughts?
