PO's Lift Job
cdoggwsu
Olympia, WA
So when I bought my rig, the PO had installed a rough country 4" lift. He did a pretty good job on it but I have one little quirk. The vent line for the front diff is stretched pretty damn tight. It's ok for just driving around but I haven't taken it off road yet. I'm afraid if the suspention flexes or drops too much it'll pop the line out. It's already streched as much as it can from the hardlines on the frame so can I just cut a longer piece of tubing and replace that section? What other options are there?
Yeah I saw some tips from a few of the other threads. Is regular vacuum line ok to use if some of the diff oil gets up there or should I go with fuel line or something?
Anything will work fine. Theres no pressure or anything in the hose. Me, I use fuel line hose.
