Posi in a Gator?
riflerk20
Milton, NH
does anyone know if you can weld or epoxy the rear end in one of these? This thing gets stuck on a wet leaf
Have you checked out the powerwheel forum yet?
I juiced up my daughters bigfoot to 18V, it would pull the front tires off the ground out of the hole :haha:
Does it actually have a diff? My daughters powerwheels uses one motor for each wheel, no idea what yours has.
The plastic wheels provide almost no traction, but I also had one wire come off one of the motors and it wouldn't move. Just sat and spun the other tire.
You can cut down bicycle tires and slide them over the plastic wheels :D
Are you talking about a real one (i.e. gas motor) or one of the kiddy plastic battery ones?
