y5mgisi
1 ton status
I was just told(this will require investigation) that a front drive line out of a 88-99 chevy half ton 4x4 front drive shaft will bolt right up to a 78 blazer that has a th350-203 combo with 6" lift. I guess the "down side" is that they are single joint on both sides of the shaft so no double carden on the t-case side. Also was told that at some point they switched to slip in the t-case which wont work. I hope someone has access to one and measure and verify! Would be nice to have a cheap shaft source.
