sandawgk5
3/4 ton status
The power block on the firewall by the brake booster, where does it get its power from the alt? straight off the batt?
I am going dual batts and a remote starter and all that jazz do I need to run a wire to that terminal so everything else will still get power? I might also put a 1 wire 200 amp alt on while I am at it. The 2 batts are a good excuse to upgrade yes?
Ira
Ira
. It looks like it attaches to the output of the alt. If so when I run a 200 amp alt then the fusible link would keep blowing.
I end-up wiring like Pauly383's diagram except my alternator hot wire leads to solenoid on my firewall.
