Power door locks and windows
pch858
Registered Member
Victorville, CA
okay this Jimmy I have has some issues 1)When I climb inside the cab and turn on the motor the power door locks lock but when I take the key out of the ignition or when I try to pull up on the door lock stock and will not let me unlock the doors I have to roll down the window and put the key in the lock unlock the truck. 2) The rear power window is really slow some thinking it's the motor is going but not sure when I use the key to have a go up it takes some time to get going. 3) the truck also has a think a six-inch lift but I want to take it back down to stock or nothing higher than in 2 1/2 inch lift. I know I'm going to need a new Pitman arm, shocks, and you bolts for the Springs but what else am I going to need to bring this thing back to stock because I only want to run a 31 or a 33 inch tire. Thanks again for all your help
