Power door locks, I think I'm missing something.
muddysub
1 ton status
Staff member
Moderator
North Branch MN
Last year I put a painless harness in my suburban while doing the LS swap. Once we got it running we basically stuck the dash back into it and made it drive-able, I wanted to drive my truck.
Now I'm tearing back into the interior and wiring to get the creature comfort stuff done before it gets too hot here. I'm trying to get my door locks going. I've got power to the switches but nothing to the actuators. Tracing wires from the switch and actuators back, they come to these two connectors I've got hanging out of the dash. So am I missing something here? The very few, ****ty wiring diagrams I've been able to find show some kind of door lock relay but I can't find what it looks like or where it's located. Can someone help me out here?
you are missing the relay that was attached to the brake bracket above the convenience modular under the dash,
yep, it's up there. Somewhere around the master cylinder push rod and brake line switch. I still have mine (IIRC) and it worked last I used it. Let me know if you need it or any bracket I'm not remembering.
It might still be there. I tried not to remove or throw out anything I thought I might need.
Damn. 4 hours from I got a problem to I got power locks.
That's worth the $25 a year right there!!
you're damn right it is! :woot::woot: what's funny is that I've owned this truck for 15 years and i'm still learning things about it from CK5.
