power lock
TXFSHRMAN
DEER PARK, TEXAS
i have a problem also with my power lock on my passenger side it will not lock with the switch i was reading the other threads and couldnt find anything with that......i can lock it and open it outside with the key...can anyone help
Does the drivers side switch work the lock?
. IIRC the switch on the drivers side is the master switch. (i could be wrong).
If the lock can be operated from the drivers side switch than the problem prolly is in the pasenger switch/wireing. If neither switch operates the lock the the problem is in the drivers side switch or the lock may have a bad solonoid.
