power steering bleeding
twoslo4five0
3/4 ton status
Living in a dump, VA
i noticed when i purchaced my reman 2wd box that it had caps on the holes where the lines went...after removing the caps i noticed there was p/s fluid in the box already...now my question is do i need to bleed the system and if so whats the best way in doing so???no hydro assist also if that helps and no hydroboost...
all I was told was to jack up the front end to move the tires easily...
then turn the wheel 1 way until it bumps.... then hold it there for a few seconds.. this will build up pressure.. then do that from left to right a WHOLE LOT OF TIMES!!!!!!!!!!!! :haha:
start with the motor off...itll get some of the air out that way instead of totally shocking the system when it cranks.
