4xcrazy
3/4 ton status
Hell, I'm just using the factory "cooler" that's strapped under the rad. crossmember. It's a 2 pass deal of Aluminum tubing on the return line. Mine's O.E..
ditto
I swapped out the auto trans in my truck, so im run my ps fluid through the old trans cooler built in the rad. Works good.
MiniWally,
Some good points there regarding line size. Something I never thought of too much in regards to AT cooler vs PS cooler & resevoirs.
To further discuss, don't the factory ps pumps 3/8 id lines on the low pressure/return side? So would it be restrictive to run the whole ps cooler system on 3/8 lines in the return/low pressure circuit? Just splicing in a tube and fine cooler (which would be less restrictive than a stacked plate cooler?) with 3/8" id tubes not good?
No I don't think so, there is just too much metal on the ends to change any direction other than the way it's run in the pictures. It totally seems like the wrong part or designed wrong. It's nothing like the OEM part.If you run the hardline part of the hose down the frame rail near the brake lines, and then make a loop or something under the pump would it fit then?
