power steering cooler ??
leadfoot067
puyallup, washington
putting a cooler on my power steering,i have a factory power steering cooler from a 88and newer chev,and its not very big.only like 3 inches by 10 inches.will this be enough?if not ill get a bigger one,just didnt wanna do it twice.
thanks
shane
Is it a tube and fin design or a stacked plate design? I have not seen a factory PS cooler.
I put in one that is a tube and fin design and about the size you listed. The truck has a AGR Rock Ram on it and it does run warm. After installing the cooler, it seems to have cooled down the PS fluid. The extra fluid capacity probably did not hurt either. I have not had a chance to wheel it too hard yet, but you can tell that yes it does help. If you can get a bigger cooler, it would not hurt. The only trouble is finding a place to mount it.
How much stuff you running of the hydro? Most people don't run a cooler at all but, I'm driving a hydro-boost brake booster, power steering, and hydro-assist ram off of it. And that’s turning 42” TSLs. So, I'm mounting a stacked plate 12" x 8". I have no idea if yours (or mine) is "big enough" or if it is even necessary. You could get all technical and try to calculate a rough estimate of the BTUs you need to shed. Or you could run it with a temp sensor (or stick a thermometer in it) and watch it. I'm just "winging it" myself and I’ll keep an eye on it when things get hot and rough...
