I'd buy a couple bottle minimum , better 3 or 4 so you have some anyway on hand at all times , if you have a couple quarts of ATF lying around you can use that too ( all I use its thicker ) , cycle steering back and forth A LOT , put some more in and cycle steering back and forth . When you see some in there through the hole put the capstick in see where the marks is
