So, I did some searching and found a great thread about power steering problems and adding coolers and it answered 95% of my questions but left me with one unanswered. Here's the deal:
I am adding a cooler and while doing so come to find that it looks like the PO used ATF instead of the PS fluid so I need to flush, etc. My question is: I want to get a couple quarts of fluid and cycle a bunch of PS fluid through the system. I need to know the way the fluid cycles through the PS system. Does it go from the steering box through the cooler into the pump and then back to the box? Or, does it go from the PS pump throught the cooler and into the box and then back to the pump?
Also, when I flush the system with new fluid do I put the hose coming off the gear box into a new quart of fluid and a discharge hose on the return line off the pump to empty the old junk fluid. OR do I suck the new fluid up into the pump and discharge the old fluid from the hose off the box? Or, am I totally messed up on my thinking of how to flush the old fluid out and get some of the new fluid in. Hope I didn't confuse anyone on my question as I had to think hard about it while typing. Thanks.
Hoby
Hoby
