Mountain_man
I'm trying to figure out which line goes where. I'm pretty sure I have it correct however it makes noise after warmed up.
The From the low pressure side of pump which side of the box does that line go into? Farther of the 2 on steering box or closer of the 2? I've bypassed the set of lines below the radiator due to a severe leak until I can get a real cooler. Need help as soon as poss so I can try to fix the dang power steering whine.
