(Note, the above picture is not my project but a pic from the Internet. I use it to show how I plan to use the Scout II steering box)
I have a 1956 Chevy 4x4 pick up that has a D44 front axle out of a '72 Blazer. I am tired of the Armstrong manual steering and am ready for some power steering. I looked at using the steering box from the Blazer (or a GM Saginaw 2wd box for crossover steering) but because the 56 frame is wider in front than later model GM trucks, on a hard right turn the LF tire hits the steering box itself and limits turning radius to the right. I have studied and looked for a couple years and have decided to use a mid-70's IH Scout II ps box with a crossover setup. This box sits atop the frame rail and only the sector shaft is to the outside of the frame and won't interfere with tire movement.
My questions are:
1. will the power steering pump (and hoses) on my small block V-8 Chevy motor hook right up to the Scout II Saginaw ps gearbox? Both GM and Scout boxes are Saginaw brand so I hope the hose threads are the same .
2. will the end of a GM crossover drag link fit the hole in the pitman arm on the scout box, or do I need to swap arms? If so, will a GM pitman arm fit on the scout sector shaft? Will I need a custom pitman arm made or is there one out there on the market for this application?
3. Are there any other things I need to consider that I may not be aware of?
Thanks in advance for any advice.
