Power steering lines
Resurrection_Joe
1 ton status
Gettysburg, SD
I need one or two of the fittings that are hooked to the steering box, the short hunk of hard line that then goes to soft line. The O ring type.
Are the ones from a 78 the right ones? If so $10 plus the ride sound ok?
Yeah I did I'll take them off today and get a pic of the end /forums/images/graemlins/thumb.gif
78 won't work o-ring style are 85 and up steering boxes. I just had a new line made for mine 79 steering box 85 pump, pump had o-rings box had flange type.
80 and up are O ring type, officially
79 older are flared normal
i just threw out a billion lines and fittings and hoses, some brand new, you should have said something sooner :/
i might still have the short O ring line, thats the lo side, it uses clamps, unlike hi side
io might hjave hi side entire hose, ill have to check and see what style ends it got,
PM or email me with p/s hoses lines subject and ill check around
thanks
I dunno i bought the steering box from Brent (8_Your_H2) and I have no idea whats what
Ok I back searched looks like I need some for an 85 box
Sooooo whatcha got!?
OKEY DOKEY LISTEN UP
I NEED THE LINES AND COMPLETE PUMP AND/OR PUMP FITTINGS
THEY NEED TO COME OFF A TRUCK WITH O RING TYPE LINES
