Power Steering Problems
cbbr
1 ton status
High velocity, Low altitude
Looks like its leaking from the top of the gearbox where the shaft goes in. Leaking pretty good when the pump is pumping.
LMC only shows a full Gearbox. Can anyone tell me if this is an easy fix.
yeah i realized that didn't make sense(notice the edit)... at first i thought you meant on the top where the hose screws in but im pretty sure there is a seal where the shaft goes in... LIttle help?
Mine appeared to be leaking from the same general place (pretty hard to see clearly) so I had some of that stop leak powersteering fluid around, and added that. Problem seems to have cleared up.
Here try this.
