power steering pulley?
OKIEnVA
Stillwater, OK
i got a 91 blazer with a serpentine belt. and heard a horrible raquet today and a bolt at the bottom came out and was rubbing the inside of the pulley. i got it threaded a lil bit enough to stop the noise, but how do i get the pulley off so i can get in to it and tighten the bolt?
pressed on and need puller and then when done need installer. auto zone has the complet loan a tool kit.
Be warned though, I've taken a few on and off but once it just DID NOT want to come off and I had to cut and grind it off of the shaft. That was a BAD day!
make sure you use an installer, you'll wreck the bearing if you just whack it on...
