jaybrowne671
Registered Member
Hey Guys!!
I've been away from the forum for a few years as I sold my trusty GMC a while back, but I found her again so here we are! Anyways, I went outside this morning to start her up as usual and when I did there was one hell of a squeal from the PS pump and no power steering. All was fine last night when I got home. I shut the truck down, checked the tension on the belt, checked the fluid, looked for leaks, etc. No problems. Since I had a warranty on the pump I figured I'd rip it off and exchange it. So I put the new pump and belt on, same problem. After the the truck runs for a second the belt spins on the pulley. I ran a rod down the pressure line to make sure its clear (should have been, it was fairly new), can see straight thru the return line, and the gearbox is less than 6 months old (cardone reman). Any ideas??? Thanks in advance for the help!
