Power Steering pump Options
Stomis
Professional Amateur
Roseland VA/PtPleasant NJ
Well the spring project before the truck finally hits the trail is Dedenboro Reid Racing Knuckles and cross over for the dana 44. I'm on 36x12.5s with 5in of lift and am in need of a new PS pump.
I know there are some aftermarket options out there but like PSC (I think is the name) but what else is there thats better than a stock remanned? Will I even need anything better?
i think the stock pump with crossover for 37's will hold up just fine. my 39.5's with stock push pull and stock pump worked fine until i got into some tight steering issues ie: wedged up against rocks, then i woulda wished i had something else
Stay far far away from AGR. I have PSC steering pump and it works very well. I would recommend upgrading to something a bit more powerful if you have the cash. I purchased the PSC pump when I had the V-belt setup and I have since converted to serpentine. PSC told me I could pull the pump from the reservoir and then use a remote reservoir which I did. I have the Dedenbear knuckles and an ORD crossover on my D60 and they are very beefy.
