Power steering pump
Karl Larsson
Registered Member
Sweden
Hi I need to buy a new power steering pump! I have already bougth one true ebay but that one leaked more than My old one:angry1: Where can I buy a good new or remand pump!
The pump I need is a cardone 20-8725F or simillar model of oder brand, please help me out here.
Any parts store should be able to get one especially if you have a number. Also, on real oddball parts(yours should not be, but you have two) it can be sent to cardone for rebuild. You can also purchase a seal kit and do it yourself. It's quite simple
Part of the problem I suspect is the OP's location :)
You can get *new* pumps, ranging from stock-ish to super-high-performance, from AGR @ http://www.agrperformance.com/ or PSC @ http://www.pscmotorsports.com/ I believe both will ship anywhere in the world, or you can get their stuff from e.g. Summit Racing who definitely will.
Note that they tend to sell just the bare pump, without the reservoir can, so you'll need to transplant the new pump into your existing can. Something like http://www.pscmotorsports.com/80-newer-hi-performance-power-steering-pump-w-o-can.html (not saying that specific one will fit, but it would look like that one.)
Looks like you have hydroboost, judging from the part number, which should mean you have the late-80's style O-ring connection, but double-check you have O-ring vs the Saginaw compression fittings.
-- A
Ok I Will check that out, yes I will need the reservoir can to that was the problem with the last pump I ordered true ebay the cap was cracked around one of the bolt hole! And that one was suppost to be reman I serusly dout that they presure test that one! The pump I ordered before that one leaked like an old Women between the pump and the cap! This is My problem! Bougth 2 reman pumps and they bout failed to hold the fluid and I start losing faith with remand pumps, maybe I just have hade bad luck with those 2 and just should order one more!? I have no problem ordering from companys that does not offering international shipping because I have
A post box adress in NY. The Only up side of this case is that I Will soon be ready to compett in world champion ship of fastest power steering pump change:mad::mad::mad::mad::mad::poo:
