Power steering pump
TJ1978
I have MANY questions
East Valley, Arizona
Having a hell of a time removing this bolt in order to mount the pump and bracket to the block...
Any tips? Doesn’t help this chrome thing is super slippery... ugh
I have no vice to hold it
Do you have an impact and a thin socket?
Ok next question
What size of whatever it is I need will plug this water pump hole?
Don't bend the can on the pump, ie NO vice. You need a thin wall socket that fits that bolt well.
Will get a thin socket set...
next question what size bolt goes on the water pump pulley?
I’m going to electric fans. So no clutch or anything will be used...
i hope a set at Ace would be cheaper than this
Should be 5/16 fine thread
I highly recommend purchasing one of these tools and hanging it on the wall. It's saved me a ton of time.
I keep saying “oh, I’ll remember”
Then to google for 2 hours trying to find “bolt size for chevy crank pulley” or whatever.
Since you have no vice, for the water pump plug I'd suggest installing it after the pump is bolted to the block. Being pipe thread it'll get tight before it's actually tight and it'd a pita to hold and tighten by yourself.
