First inspect the can, if it has any bend bows or dents, it will leak. If so get a replacement. you would need pressure gauge @2500 psi and fittings to connect to pressure port. block return line. you can spin the pump with an air tool using the hex or thread a bolt into shaft should make @ 1200- 1300 psi stock 1500 modified.
I cannot for the life of me get this damn bolt out. The nut is going to round. I tried thin wall impact, box wrench etc. All I have I threw at it. It will not budge.
I can use the old stock bracket but in order to use this ICT bracket that nut needs removed.
Throw the 12 point socket or wrench away and use a six point socket or wrench. !2 points have a habit of rounding off
the nut or bolt as shown by you picture.
