Wondering if anyone has ever ran into this, I recently finished rebuilding the front end of my 89 Jimmy, new ball joints/wheel bearings/hubs/tie rods/all steering linkage. Replaced steering box and pump and both hoses because the box leaked profusely. Got a Lares reman box and a cardone reman pump. Bled system as follows:
Engine off, truck jacked up, turn steering lock to lock many many times
Crank engine, turn lock to lock even more times
I could not get it to bleed, the steering was always tight and jerky, it would turn ok in the air but when you drove it the steering was tight. So i figure I got a fubar reman pump, well I just got its warranty replacement installed this evening and I have the same problem. There are no visible fluid leaks anywhere. I can see microscopic bubbles in the fluid in the pump while it is running. No bueno in a hydraulic system. I am at my wits end, could it be the box that is leaking air somewhere? Is every reman steering part just an absolute POS??
