power tanks What Size is needed for weekending
sheswatchingme
Sturgis SD
Hey guys, need to get a power tank for the tire let down thing, hopefully wont use tools, what would you recomend for size tank for weekending and tires only, how many 39.5's can you are up on different tanks, also do the let down valves work reliable? Thanks PS Just got my 73 sprayed with left over WW11 airforce yellow imron, will post photos later. sheswatchingme
10 pound bottle should be plenty, especially if you aren't going to run tools. Not 100% sure how many air ups / downs you get from 1 bottle, but unless everyone on the wheelin trip is snaggin' your CO2, you oughta be fine.
j
SchnorrCS said:
Not to hijack, but how/where/how much are these power tanks to fill up/get filled up?
just under 20 bucks here, you can get them filled at alot of the same places you would go for your welding needs, I had a tank filled at a drive through liquor place here in mesa:haha:
$10-20 around these parts. Welding places, gas cylinder supply places etc can fill them up np.
j
Which place is this and where? Sounds pretty convenient!!:D
either country club and main or mesa drive and main, cant remember which, but it was on the east side of the road.
