power window oddity
k20
3/4 ton status
Mineral Springs, NC
Yesterday I ran to the gas station, rolled both windows down from the drivers side. Got back to the house, couldnt run the passenger side up from either switch. Pulled the wiring out, and one of the wires was broken loose in the connector, rigged it up with a jumper wire and rolled the window up from the drivers side and I couldnt from the passenger side
Today I changed the connector on the passenger side, and I still cant roll the window up from the passenger side switch. It will roll down from both switches, but only up on the drivers side. Where do I need to start checkin?
