Recently I tried to do the standard 4 relay mod for my power windows. Diagram pictured below
The issue that is mind boggling to me is that I followed this, (yes I know it says Trans am but the colors are the same, thanks GM) HOWEVER all that happens is that my relays click. No window movement whatsoever. If I put my voltmeter on the plug that goes to the motor, I get 12v. I know for sure the wiring is correct because if I jumper the 86 and 30 pins, which would take me back to the original wiring style, the windows will move for me. The grounds are good too, and they would have to be otherwise my relays wouldn't click. Hoping for the best as the slow windows leave much to be desired.
Thanks in advance
Thanks in advance
