embarassed to admit this but I can't seem to get this mod working correctly.
This is the schematic I was working off.
This is how I ended up wiring it. The only way it would work was if I had power passing through the switch which seems to kinda defeat the purpose of the relays.
I checked the wiring like ten times and even tried different relays but nothing worked until I put power back into the switch.
What am I missing here? Seems to me that the relays should switch the power between the blue and brown wire depending on how to pressed the window switch. Without power run to the switch nothing was happening.
