SLO C5
My passenger side, front power window won't budge. It's stuck in the up position, thankfully. Is there a way I can do some preliminary diagnosis on it before I pull the door apart and/or buy a new motor?
I've seen some motors on ebay for $11 + shipping, should I avoid them? The ones at Kragen are $40+. LMC is $50.
Can I take apart the 4 window switch on the driver side door and connect the wires from the passenger front window to one of the other 3 switches to see if that is the problem? That switch doesn't have one of the clips on it that hold it to the door panel, so I can easily get right behind it and play with the wires, if this is a way to troubleshoot it?
