badbowtie03
Registered Member
Hey everyone I have an 87K5. Both gas gauge and electric windows were working... I don’t think it’s related but I tuned the truck up... plug wires distributor etc... Then the next morning the gas gauge was on empty... ground issue? Anyways today I checked the ground by the gas tank and unplugged and plugged back in the wiring for the fuel pump. It all seems fine?
So also, two days after the gas gauge quit... both front electric windows stopped working at the same time... One night they worked and I put them up and shut the truck off then when I tried to start it in the morning they wouldn’t go down...
Could these be related? Maybe an ignition problem? I checked the fuses under the dash and they seemed fine. Should I take a door panel off and see if power is going to the electric switches? Any ideas? Thanks so much!!
