Powerglide tranny bracket
mkmiller
Magnolia, Arkansas
Looking for a powerglide transmission bracket for a 2wd 1969 chevy. I believe anything from 67-69 will work. Just let me know if you have one. thanks, Matthew
What kind of bracket do you mean? Do you mean a crossmember? AFAIK the trucks never used a powerglide trans, FWIW though the aluminum powerglide is the exact same length and spline count as a TH350 and the trans mount is also in the exact same place relative from the front bellhousing back.
Thanks for the info. They put powerglides in the trucks from 67-early 69(for sure). The bracket that the shifter arm(from column) attaches to is different on the PG and Th350. I tried to use a th350 and it is different. I basically need everything from the rod that attaches to the column to what connects to the tranny itself. I bought the truck and got it running and driving but the PO kept the tranny linkage for whatever reason.
Well if GM installed powerglides in any of those trucks it's news to me. I've owned several of them one being a 69 and that had a TH350 originally installed (had the build sheet on the truck). My guess would be that GM may have installed the powerglide into 67 and possibly 68 trucks but my guess would be more than likely 67 only.
Sorry i'm of no help to you other than giving you this link. Look at this website and give Bill a call. He knows EVERYTHING there is to know about these trucks. He is in my home town not far from me and i've known him for years now. He has many new and used parts available. You might need to leave a message but he will call you back. http://www.vintagechevytrucks.com/index2.html
Thanks for the link Scott, I'll have to give him a shout. This is actually the first 69 I've seen with a PG but I do have the spid on the glove box that shows it to be factory. It had a 250 backed by a PG. I've seen several 67-68's with a glide but this is the first 69.
