84_Chevy_K10
Banned
It might screw in, but it isn't going to seal. I couldn't get the metric o ring fitting to screw into a flare fitting box when I installed my crossover and had to switch to the other box I had laying around, but I suppose the opposite is possible.
The thread diameter of the metric o ring fittings are slightly larger than the flare fittings. So, if you screwed the SAE hose into a metric box, it might thread in, or seem to, but it's not going to seal. There is no 45* surface inside the box for it to seal against, so it is going to leak without question.
I'm really not trying to be cocky in this response here. If your box has different fittings than the hose, it's just not going to seal correctly. To avoid the hassle, it's just easier for me to tell you that right now than have you go out and leak power steering fluid all over your floor.
And as to 85, 86 C10, etc. It doesn't matter. If it's from an 82 and later truck and has an O ring fitting and the 2wd sector shaft, they're all the same. Same with 4wd, the only change throughout the years that I know of is in reguards to the power steering hose fittings. Other than that, a 4wd box is a 4wd box, as a 2wd is a 2wd box as long as we're talking power steering boxes here (manual box might be different).
