I agree the cheapest ready made brake lines with fittings already installed do rot away in 2 years or so in salty climates...its just galvanized recycled crap steel most of the time..
You can buy 25 foot bulk rolls of brake tubing though,which comes in a few different varieties--some is the same cheap galvanized stuff,the next step up is a tubing that has thicker walls and is coated with a greenish teflon type substance,that does resist corrosion better and will last longer--the next step up is a nickel/copper "terne" metal that is thick and wont rust,but is also a bit softer than steel,easier to flare,and is worth the extra cost if you plan on keeping a vehicle a long time and dont feel like replacing rusted lines every couple of years..
The only drawback I have found to this stuff besides the price,about double what the cheap stuff goes for,is the fact you cant usually get the tubing nuts to unscrew once they are tightened,it tends to become "permanent"--so if you need to replace a wheel cylinder ,etc,it may not want to unscrew,it'll twist up the tubing instead..you can just leave a little "slack" in the line so you can just cut off the nut fitting and install another,and re-flare it again..
If I were rich I'd buy stainless steel pre bent lines--but I have doubts about getting any installed without having to bend them --I have helped a few friends install them on vehicles like a 62 Nova and 72 Chevelle,and we had a very hard time installing them,it would be simple if the body were off the frame,we had to cap the ends of the tubing to keep dirt out while we threaded them thru the frame and body areas and some had to be "tweaked" into place..stainless is brittle and if you bend it a tad too much,it'll crack or break..on a truck it might not be as difficult,but on these cars,a frame off restoration is the easiest way to put the lines on in the factory location..
