Which one is which? I have an issue with loosing fluid and I think its due to the extra cooler and I have the lines reversed. Basically every time I go to drive the truck I have to add about a qt of atf to get it to move. I believe I have the return and pressure lines switched up. I know in a perfect world I could get the dipstick oring to actually seal, but I have tried about everything and cant get it to seal 100%. So it leaks out. Then when the pump pushes fluid to the cooler and then there is not enough for it to move.
Thoughts and Ideas?
Thoughts and Ideas?
